🎉Community Raffle - Win $25
Join and Win
error 1253
User: "yehoo"
Altair Community Member
Updated by yehoo
hi,
does anyone know what is error 1253 and how to solve it?
thanks
1 - 3 of 31
    User: "Pranav Hari"
    Updated by Pranav Hari
    Hi yehoo
    Can you please elaborate more on your issue.
    Share the .OUT file also
    User: "yehoo"
    OP
    Updated by yehoo
    i'm trying to perform Multi Body Simulation using Hypermesh because there is a Problem with Motionview.
    This model consist of 9 moving components. i have set all the boundaries, Motion, gravity, contacts, joints and everything (as far as im aware). i have followed the guides from OS-1940. When i try to run the calculation, this error showed up.
    User: "Pranav Hari"
    Hi yehoo
    I can see from the .OUT file, that the gravity has zero value. Please update it
    Also, the shell elements are not assigned with PSHELL property. Check and ensure whether all the shell elements (quad4) are assigned with a PSHELL property.
    If the error still persists, please share the model file.
    You can use the secure transfer link if needed.
    https://ftin.india.altair.com:8443/filedrop/~Ma3TaE
