Dear,
I have a model with different solids for meshing purpose. But the problem is that I can't do any boolean operation between two solids. I got an internal error. What could be the problem?
Best regards
Nestor
Hi Nes,
I'm able to do union of two solids (A+B). Please can you show me what is error you are getting?
Thank you
The only error message I am getting is internal error (see image)
Nes,
Under combine through option, select all internal faces and try.
Hi Nes,
Thank you
