Non-Linear Static Analysis
User: "Habib"
Altair Community Member
Updated by Habib
Hello
I am an Automotive Engineering student at Uludağ University, I am writing from Turkey. I am working on a project and I think I need your help. I am trying to do non-linear static analysis of a part used in automotive in HyperMesh, but it gives errors in some parts, I would be very happy if you could help me.
Thanks.
1 - 3 of 31
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Hi Habib,
    welcome to the Altair Community.
    I assume you're running OptiStruct, right?
    If that's the case, OptiStruct solver writes some output files, such as .out files.
    You can share these in here, and tell us a little better what kind of model are you running (contacts, material, etc)
    User: "Habib"
    OP
    Updated by Habib
    Hello.  Yes I am using OptiStruct, I am sharing the .out file with you. Let me also share the HyperMesh file  The error I noticed: 3D mesh quality fails on bolts, pins and bushings. There is a 100% error rate for LENGTH.  Error given by OptiStruct: *** ERROR # 4965 ***  Maximum number of time increment cutbacks reached,  analysis aborted.   I am also adding analysis information.  Thanks for your help.
    Altair Employee
    Usually this is related to contact issues or parts not properly connected.
    Your .out file shows us that there are large Average Displacements, so a part of your model is probably flying away.
    Try running your model with the control card PARAM,EXPERTNL,CNTSTB to add some numerical stabilization to your contacts.
    Additionally, try reducing a little bit the initial increment, by settting a small DT value inside your NLPARM card (i.e. 0.01).
    There are a few tips in this post as well:
    https://community.altair.com/community?id=community_blog&sys_id=538764ab1b3790d4a5f742eddc4bcba4
