Free 1D Element
anderlanza
anderlanza New Altair Community Member
edited November 2020 in Community Q&A
Hi,
In the picture below can be seen an image of the error I'm having any solution?
Welcome!
Answers
  • Adriano Koga_20259
    Adriano Koga_20259 New Altair Community Member
    you can try using the tool 'Tools>>edges' and try to merge the loose nodes by using 'equivalence' under a certain tolerance.
  • anderlanza
    Hi Adriano,
    I tried first checking the free edges and it can be seen that in that places there is no free edge. (image below)
    Then I tried by doing an equivalence as you have set and when selecting th element I can not select the node or the cbeam element. Any idea?
    I have also thought about connecting them with RB2 elements and didn't work.
  • anderlanza
    Hi Adriano,
    I have solve it thank you very much
Welcome!
Welcome!
