🎉Community Raffle - Win $25
Join and Win
Multiple curve graphing
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Is there any function which allows me to plot two curves - one from an excel file, and the other from a simulation run onto the same graph for comparison/analysis?
Thanks in advance!
1 - 2 of 21
    Altair Employee
    OP
    HyperGraph (or the graphing portion of HyperView) can do all of the curve overlay functions. From Excel, you will need to export the curve in CSV or TXT format, but your simulation results data can probably be read directly from the solver results file.
    Altair Employee
    OP
    ETG is absolutely right. Use 'Build Plots' panel in HyperGraph (HG).
    The Build Plots panel constructs multiple curves and plots taht can be overlaid in a single window or each curve can be assigned to a new window.
    Following plot data files are supported.
    ADAMS REQ and matrix files
    Abaqus mass from DAT files
    DADS graph files
    GENESIS history files
    Altair HyperForm DAT files
    Altair HyperMesh RES files
    Altair MotionSolve files
    Altair MotionView shock output files
    Altair OptiStruct files
    Log files
    Mass, volume, and frequencies from out files
    LS-DYNA general time history files
    LS-DYNA time history files:
    • ABSTAT
    • BNDOUT
    • DBFSI
    • DEFGEO
    • Mass from D3HSP
    • ELOUT
    • GCEOUT
    • GLSTAT
    • JNTFORC
    • MATSUM
    • NODFOR
    • NODOUT
    • RBDOUT
    • RCFORC
    • RWFORC
    • SBTOUT
    • SECFORC
    • SLEOUT
    • SMDYN6
    • SPCFORC
    • SPHOUT
    • SWFORC
    • TRHIS
    MADYMO time history files
    MADYMO TQ3
    NASTRAN:
    • Mass and frequencies from f06 file
    • Complex results from SOL 108 and 111
    ‚àí Displacement
    ‚àí Velocity
    ‚àí Acceleration
    ‚àí PSD (displacement, velocity, acceleration)
    ‚àí SPC force
    ‚àí Element force (CELAS, CDAMP, CBUSH)
    • HyperView results from OP2 files
    PAMCRASH time history files
    RADIOSS T01 time history files
    WINGZ DIF files
    General
    Excel (.csv)
    Multicolumn ASCII
    XYDATA files
    User-defined import templates and external readers to directly read any file format
    Tab delimited files
    In addition to the standard set of import templates, an open interface for creating custom import filters is provided. Using import language and external readers, you can write import templates for most any ASCII data file not directly supported in the program.
