Import from excel
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello all,
I have a list of coordinate point of coil spring model in excel.
Is there a possibility to import this point coordinate information to Hypermesh so that nodes as well as lines can be generated ? Using tcl command maybe? or notepad files?
Thank you very much in advance.
1 - 4 of 41
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi there,
    it's a very simple tcl code,
    like this ex.
    your excel file ==> Save as... CSV format:
    xCoord,yCoord,zCoord
    0,0,0
    1,1,0.5
    1.4,1.4,1.0
    tcl file:
    #read the csv file
    set csvfile [open csvfilename.csv r]
    set NodeList {}
    while {![eof $csvfile]} {
    gets $csvfile line
    set NodeCoords [split $line ,]
    #create the nodes
    if {![catch {eval *createnode $NodeCoords 0}]} {lappend NodeList [hm_entitymaxid nodes]}
    close $csvfile
    #create sprial
    eval *createlist nodes 1 $NodeList
    *linecreatefromnodes 1 2 150 5 179
    I usually write tcl codes like those
    If you need my help, don't hersitate
    image/emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'>
    rgds,
    Altair Employee
    OP
    @Tinh: Hello, I have almost similar issue.
    I have an excel file (.csv format).I need to retrieve the data in my first column as a list.
    I placed my csv file in my TCL script folder and tried your above TCL script i.e.
    'set csvfile [open MaterialData Al6063 - Copy.csv r]'
    'Tcl script error (Tcl/Tk Script) : wrong # args: should be 'open
                  fileName ?access? ?permissions?'
                  while executing
                  'open MaterialData Al6063 - Copy.csv r'
                  invoked from within
                  (file 'D:/RWTH/Mini thesis/V6/TCL V4/Untitled3.tcl' line 6)
                  invoked from within
                  'source {D:/RWTH/Mini thesis/V6/TCL V4/Untitled3.tcl}'
                  ('uplevel' body line 1)
                  invoked from within
                  '# Compiled -- no source code available
                  error 'called a copy of a compiled script''
                  (procedure '::hw::RunTclTkScpt' line 1)
                  invoked from within
                  '::hw::RunTclTkScpt 219' '
    I would be really glad,if you can look at the above issue and reply.
    User: "tinh"
    Updated by tinh
    Hi,
    it should be :
    set csvfile [open 'MaterialData Al6063 - Copy.csv' r]
    because your file name has space
