Run solve in classic hypermesh interface
tonychen
tonychen New Altair Community Member
edited January 2023 in Community Q&A
hi all,
i face a problem,i want to run my case in hypermesh windiows,
after i choose input file and solver, then i push "solve",but
there is no any reaction(not calculate), only jump the cmd windows,
how  should i run in this classis hypermesh interface? thanks alot
Best Answer
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited December 2022 Answer ✓
    I believe this menu is not suitable for Dyna, only for OptiStruct and a few other result translators.
    I believe it is easier to just export the .k file and run it into the Dyna console.
    Otherwise you need to create your own batch routine, and specify arguments such as:
    i=jobname
    npcu=numerb_of_cpus
    memory=allocated+memory
    Maybe you will also need to have the license environmental variables set in your system.
    https://community.altair.com/community?id=community_question&sys_id=4c494bdddb00f450e8863978f49619cf
    You could also try to use the TCL console to call your executables from the command line.
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    i=jobname
    npcu=numerb_of_cpus
  • tonychen
    i=jobname
    npcu=numerb_of_cpus
    thanks alot
Welcome!
Welcome!
