🎉Community Raffle - Win $25
Join and Win
Ceramic Fatigue Analysis
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Any Idea, how one can perform fatigue analysis of structural ceramic materials?
Thanks.
1 - 6 of 61
    Altair Employee
    OP
    Hi Giri,
    what material propertied do you have for ceramic?
    What is your end objective?
    Altair Employee
    OP
    Hi Giri,
    ALON, aluminium nitride.
    Major props:
    Structure                         Cubic, Spinel
    Lattice Constant              7.956–7.936 Ã…
    Density                            3.69 g/cc
    Form                               Polycrystalline
    Melting Point                  2150°C
    Young’s Modulus           320 GPa
    Shear Modulus                135 GPa
    Poisson’s Ratio               0.24
    Hardness                         1800±100 kg/mm2
    (Knoop indentation, 200g load)
    Fracture Toughness        2.0MPa-m1/2
    Flexure Strength             300-700 MPa
    Specs: http://www.surmet.com/pdfs/ALON%20Data%20Sheet.pdf
    Objective: Cyclic loading. HCF. Find the damage, life expectancy.
    Altair Employee
    OP
    Major props:
    Density                            3.69 g/cc
    And Weibull model is used for reliability analysis, instead of SN curve. No idea, how can I use it in Hypermesh.
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    If model is having shell elements you can try with Radioss XFEM to simulate crack propagation.
    Regards
    Rahul R
    Altair Employee
    OP
    Hi,
    Regards
    Rahul R
    Great but I don't have any idea. Is their any documentation (tutorial) or sort?
    Can't it be done in Optistruct?
    Thanks.
    Hi,
    I have attached few examples of XFEM for crack propagation.From Radioss 14.0 it will work for solid elements aswell.
    In Optistruct we can do fatigue analysis using stress & strain based approach(Not sure for cermaics).Refer online tutorials for more information.
    Regards
    Rahul R
