Hi @WikiJoy
With the backward and forward motion, is it a translation motion or a rotatory motion?
The hinge (look alike) part below the datum line, is it a different body?
You can apply a motion and get the torque which can be used to calculate the force.
Hi @WikiJoy
There are three (3) bodies in this figure. Part B is pin which is connected with part C and Part A. Part C is the the Linear actuators which i also attached the picture. Part C translate the motion with hte part B then part B rotates the Part A. So, I want to calculate the force that how much force is required of Part C (Actuators) which can rotate the Part A in Alpha1 & Alpha 2 direction and how we will simulate in hyperworks?
Hi @WikiJoy
Please see the image below. Here part C which is the actuator is not shown.
Part is connected to ground using a pin joint and a motion is applied on it and torque is calculated.
From the toruque and the length of the actuator (force application point) calculate force using Force = Torque / [Length * sin (Angle)]
Hi @WikiJoy
What would you like to simulate?
