Property invisible
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hey,
I used to have 4 properties (1 solid, 2 shell, 1 beam) in my model. My problem is, since shortly HM does not display them anymore. I can still see the beam property in the model explorer, but none of the other 3. Strange thing is, when I exported the solver deck, the properties have been written correctly to the keyword-file. As I tried to create the missing ones again, HM promted that properties with this name already exist. Has anyone else experienced this bug?
Best Regards
Gottfried
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2015
    HI,
    Please try the below:
    Close HyperWorks application(s) and Please delete setting files on your machine. Follow the link below on how to delete setting files:
    http://forum.altairh...iles/?hl=delete
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-23811200-1425890772_thumb.jp
    Also, delete .Altair folder in temporary directory. Go to Run and type
    in %Temp% and click OK.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2015
    Thank you for your fast response!
    I tried both but nothing has changed so far..
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2015
    Hi,
    could you please share the .hm file?
    Please share the file using the dropbox link available in my signature below.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2015
    Sadly this is not possible since some details of the model are confidential.
  • Rahul_P1
    Rahul_P1
    Altair Employee
    edited June 2015
    Make sure the properties are active in the entity state browser, if they are not active as in the image below, then they will be invisible, however they will export since the export option is checked.
    <?xml version="1.0" encoding="UTF-8"?>post-4438-0-87754100-1433854129_thumb.pn
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited June 2015
    And now I'm as much ashamed as happy again...
    Thanks a lot!
Welcome!
Welcome!
