Altair RISE
Nominate Yourself Now!
Error in solid element connectivity, the first 4 nodes must be unique
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi, everyone
Thanks for reading this topic.
When I submitted a job, I got the error information:
*** Error 20222 (STR +222)
      in solid element connectivity, element 103338
      the first 4 nodes must be unique.
Then I find this element 103338 and check element, there is no problem with its connectivity and duplicates (see the bellowing picture). It is very confusing.
If I delete this element and translate + duplicate an adjacent one and then equivalence nodes, the error will still exist, but in another different element. I don't how many elements has this problem.
I also tried renumber all, but it is still useless.
I really want to have your suggestions if you are familiar with it. Thanks a lot.
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.744bdff982e2ad3f6b5e983d27d75dd7.png
1 - 5 of 51
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Try duplicating all elems.then delete the originals
    Could you share *.fem file?
    Altair Employee
    OP
    Thanks a lot. I will try and see if it works
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    Instead of translating and duplicating the element, can you please try and create a new element from '2D' page 'edit element' panel.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.cb36440dac6dee43541850ee7c1d1fa5.png
    Thank you
    Altair Employee
    OP
    Hello,
    Thank you
    Thanks for your help. I can create new element use the edit element panel. But the next analysis will still have the error with another element.  I am really confused. I want to find out every element with this problem and correct them all.
    Hello,
    I would suggest you to try this method a couple of times but if the problem does not go away please consider re-meshing the whole thing.
    Thank you
