🎉Community Raffle - Win $25
Join and Win
HyperMesh translational joint for ls dyna
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Could anyone show me how to create the translational joint in HM for dyna?
1 - 16 of 161
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    Select menu Preferences>UserProfile => Select profile 'Ls-Dyna' => OK
    enter 1d>joints
    select join type 'translation'
    pick nodes to define the joint
    Altair Employee
    OP
    Hi,
    enter 1d>joints
    Yes ,I knowen, but how to define the nodal rigid ?
    Altair Employee
    OP
    the triple nodes like the graph below
    User: "tinh"
    Updated by tinh
    Hi,
    bind each triple nodes by 1d>rigids, don't forget to bind them with regarding component, too
    Altair Employee
    OP
    Hi,
    Yeah, I do as you telling me . And .....
    *** Error 20393 (STR+393)
         Nodal rigid body ID 19 contains node ID 123414
         already used in a rigid body/nodal rigid body definition.
    Altair Employee
    OP
    Did you use ls dyna solver? or HW?
    Altair Employee
    OP
    dyna SOLVER
    Altair Employee
    OP
    Hi @Aurora!
    if i were you i would do a small test-task with only connector in ls prepost. you can see how it works and redo it in HM.
    another way, if you use rigid bodys in ls dyna, you can not connect it by rbe2 instead you should use extra nodes set.=)
    Altair Employee
    OP
    @Aurora!
    Did you solve problem?
    Altair Employee
    OP
    @Aurora!
    nope
    Altair Employee
    OP
    Hi @Aurora!
    Yeah,rbe2 element can't connect the rigid elmemt .
    Altair Employee
    OP
    i had done revolute joints in LS DYNA, but i hadn't problem.
    User: "tinh"
    Updated by tinh
    Hi,
    if the component is RIGID, please use XtraNodes to connect the comp with the joint's nodes
    Altair Employee
    OP
    how did it work? Could u share it to me ? thx
    Altair Employee
    OP
    Hi,
    thx, I will have a try. but if the component is not rigid ,how to solve it ? Could you give me a advise?
    User: "tinh"
    Updated by tinh
    Bind it with the joint by a rigidlink
    F10 check 1d>dependency
