🎉Community Raffle - Win $25
Join and Win
Hypermesh element selection
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hii, I saw one command named 'spherical cli' in built up menu which selects elements in a circular manner. The centre and radius of that circle is given as input. Is there is any command which helps in rectangular shape selection with the centre and width & height of rectangle being given as input??
1 - 2 of 21
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi, it is not element selection, clipping is just to cover exterior portion of the sphere
    if you want to select elements, using *createmark elems 1 'by box'
    search for args of *createmark in Hypermesh reference guide
    by GUI, hold down shift + LMB to pop up advanced selection options
    or by entity button, select 'by window' also help you select elems by rectangular shape
    Altair Employee
    OP
    thank you
