Altair RISE
Nominate Yourself Now!
Obtain the area and perimeter of geometry in Hypermesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Please, how can I obtain the area and perimeter of a 2D model in Hypermesh? Thank you.
1 - 10 of 101
    Altair Employee
    OP
    hi,
    I think u can use Tools>Mass Calc.
    There by selecting elements you will get area.
    perimeter
    geom>Length
    by selecting lines you will get.
    Altair Employee
    OP
    @mahes
    Thank you so much.
    Please, how can I obtain the minimum area bounding box for a geometry in hypermesh?
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    3d page : tetramesh : refinement box
    User: "tinh"
    Updated by tinh
    @mahes
    Thank you so much.
    Hi,
    Try:
    *createmark surfs 1 'Select geometry'
    puts [hm_getboundingbox surfs 1 0 0 0]
    Altair Employee
    OP
    @tinh
    Thank you.
    I am using hypermesh GUI. I do not know how to do tcl scripting. Please, what is the equivalent procedure for those codes in hypermesh GUI?
    User: "tinh"
    Updated by tinh
    Sorry Samuel,
    it should be:
    *createmarkpanel surfs 1 'Select geometry'
    you will be prompted to select your surfs, and it will output (at command window) bounding box
    I don't know other way to get it by hm GUI
    Altair Employee
    OP
    @tinh
    Thank you. Where should I input these commands?
    Altair Employee
    OP
    @tinh
    @Prakash Pagadala
    Please, find my attached geometry.
    I want to implement topography optimization.
    Minimum area bounding box around my model = m
    perimeter of the model = p
    compliance = c
    f = m + p
    Objective = minimize f
    constraint: lower bound = 0.2*c, upper bound = 0.8*c
    How can I implement this? Note that perimeter and minimum area bounding box are not included among the design responses in hypermesh.
    Thank you.
    Altair Employee
    OP
    Hi Samuel,
    isn't the unit of P and M are different?
    This makes F complicated parameter...?
    I need to check if there a way to provide geometric responses in OptiStruct
    Altair Employee
    OP
    @Prakash Pagadala
    Yes, the units are different. But that's what I need to achieve.
    Thank you.
