🎉Community Raffle - Win $25
Join and Win
Problems with units exporting the solution of Inspire Mold
User: "Juan Torres"
Altair Community Member
Updated by Juan Torres
I have some problems with the units because i am new using hypermesh and I don´t know why when i export the files of inspire mold analysis and then import the c2mRun_fiber_main.fem on HyperWorks the measures changes.
In the next images you can see the real measures on injection molding.
And now how I import the mesh of the injection molding analysis result on HyperWorks.
As you can see the measurements changes in the import, how can i made them stay with the same magnitude? Because I need the file in the right measurements for the nexts steps.
1 - 2 of 21
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Inspire internally works in SI.
    So you model will be exported in SI.
    In HM, you will need to scale your model (and properties) accordingly.
    User: "Juan Torres"
    OP
    Ok so, what steps do I need to follow for scale the model, the results and the properties properly?
