🎉Community Raffle - Win $25
Join and Win
angle between two liones in sketch
User: "mpvnaresh"
Altair Community Member
Updated by mpvnaresh
Hi
How to measure angle between two lines in flux 2D
1 - 2 of 21
    User: "Alejandro Rodríguez"
    Altair Employee
    Updated by Alejandro Rodríguez
    Hello.
    Unfortunately, there is no direct way to measure the angle between two lines.
    Depending on your project and your goals you can used different method to obtain this angle automatically:
    -Through a python file programming the trigonometric relation (since you have the coordinates of all the segment’s points).
    -You can also define a cylindric coordinate system centred in your line intersection.
    Best regards.
    User: "mpvnaresh"
    OP
    HI..
    Thanks for your quick reply .
