Altair RISE
Nominate Yourself Now!
Upgraded to Monarch Classic 15, now unable to export to Access
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Recently upgraded Classic to v15. Have a regular process where I export a dataset to a access database, nonissue when using v14. This now fails when run via v15 with no helpful information as to why?
Any idea's?
1 - 10 of 101
    Altair Employee
    OP
    Hi Vanessa,
    This appears to be a bug.  Both table and summary export to .accdb fails if add to file is selected.  If overwrite file is selected, then it works.
    You can open the project file in DPS, and export table to .accdb, which works file, however, currently summary export to .accdb is not supported.  Summary can only be exported to a .csv file.
    I reported this issue to Datawatch support team.
    Regards
    Mo
    Altair Employee
    OP
    Hi Vanessa,
    Regards
    Mo
    FYI, this bug has been reported and will be fixed in Monarch v15.2.
    Regards
    Mo
    Altair Employee
    OP
    Regards
    Mo
    When will 15.2 be available?
    This is affecting critical processes.
    Altair Employee
    OP
    Vanessa,
    Is it safe to assume that you have full maintenance support available?
    If so I would strongly suggest that you create a support case if you have not already done so. That may, in some circumstances and situations, provide for the earliest possible solution to a mission critical problem. It has to be worth seeking that opportunity.
    Grant
    Altair Employee
    OP
    Hi Vanessa,
    A temporary workaround is to downgrade to Monarch v15.0. I believe you're using Monarch v15.1 right?
    I will give you access to our support portal where you can download the installers. Please expect an email with a password creation link. I also created a ticket for you to make sure you will be informed once v15.2 is released.
    Altair Employee
    OP
    Hi Vanessa,
    Have test v15, this does not work either
    Running export job Export1
    Export job Export1:
        Failed - Export1
            The Excel file is incompatible with this version of Monarch.
    This is urgent, we cannot undertake critical business processes
    Vanessa Lowther
    Senior Financial Data Analyst
    Pay360 by Capita
    30 Berners Street, Fitzrovia, London. W1T 3LR
    Office: 01225541862
    Email:vanessa.lowther@capita.co.uk<mailto:Vanessa.Lowther@capita.co.uk>
    www.pay360.com<http://www.pay360.com>
    Part of Capita plc www.capita.co.uk<http://www.capita.co.uk>
    Altair Employee
    OP
    Export job Export1:
        Failed - Export1
    Vanessa Lowther
    Pay360 by Capita
    Office: 01225541862
    I can confirm that the same is happening to me since I installed v15.1!
    It's not very reassuring to have to await the v15.2 release when critical business processes are at stake or even to go backwards, however, I thankfully kept my original v14.3.2.7917 installation which still works.
    Altair Employee
    OP
    Hang on a minute. Your original post was back in August so why, now in November, is 15.2 not yet available?
    I'm going to get in touch with support now...
    Altair Employee
    OP
    Ah, it looks as v15.2 *was* released but I was recently given v15.1 and received no further notifications!
    Please could we make the upgrade process simpler, Datawatch? If I don't have the option to check for the latest updates within the program, at the very least communications should go out to inform everyone of new releases.
    Altair Employee
    OP
    Hi Alex,
    Thank you for providing your feedback and apologies on the experience.  If you are a member of the Support Portal you will then want to "FOLLOW" both the Product Downloads & Latest News in which it will then provide you with an email update for Datawatch Solutions.  If not a member please Register.
    Link to the Support Portal:   https://www.datawatch.com/support/
