Derived Results
User: "jakub.ziontek"
Altair Community Member
Updated by jakub.ziontek
Hi. Is it possible to create label with displacement - displacement (from other loadstep) but resolved in user system (cylindrical)???
I can see radial displacement from each loadstep (resolved in user system), but I can't subtract it between loadsteps (see difference in radial displ - only in global axis or mag).
Jakub
1 - 3 of 31
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Maybe you mean 'Derived Load case'?
    If yes, it's simple. When you create a derived loadcase, you have a new 'derived loadcase'. Once loaded this new loadcase, just choose your cylindrical as user system to show the displacement.
    OP
    I want to subtract displacement for one load case from other and see displacement plot in cylindrical system (see radial displacement). results is ony scalar value from cartesian or magnitude, cant use cylindrical system.
    User: "Stefano Di Meo"
    Updated by Stefano Di Meo
    hello, did you find a solution? I have the same problem as you
