🎉Community Raffle - Win $25
Join and Win
Graphics in hypermesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
need graphics area aspect ratio(size) in hypermesh
1 - 2 of 21
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hey, it's a bit tough to understand your post.
    foreach {x y w h} [hm_getgraphicarea] {puts 'you've got graphic area size $w x $h}
    Altair Employee
    OP
    Hi,
    you can set the aspect ratio in the file hm.cfg (hm\bin\win64 for windows). Look at...
    The aspect ratio of the screen can be defined using the screensize command
    shown below.  The command requires two parameters which define the physical
    size of the usable portion of the screen.  The first parameter defines the
    horizontal dimension and the second paramter defines the vertical dimension.
      *screensize(13.5,10.125)
    Regards,
    Mario
