MLFMM with FEM and MoM
Hamsalekha
Hamsalekha Altair Community Member
edited October 2020 in Community Q&A
Hi,
I wish to integrate MLFMM with MoM and FEM. However, I am confused with the options given in the CADFEKO.
In the region properties box (diagram above), there is an option for MoM/MLFMM (so I assume that MoM is integrated with MLFMM).
 However, in the Solver Setting box, there is another option for MLFMM
Do I still need to tick the solve model with MLFMM option? I am not sure with the differences between the two figures?
Is it same for FEM method as well?
Thank you
Answers
  • Mel
    Mel
    Altair Employee
    edited June 2020
    The region properties has to do with the meshing.
    MoM/MLFMM with SEP does surface meshing and this mesh will be suitable for either MoM or MLFMM (based on whether you enable MLFMM on Solver Sttings -> MLFMM/ACA)
    Likewise, if you choose FEM on the region settings, a tetrahedral mesh will be generated suitable for FEM. If MLFMM is disabled on Solver Settings, this will then be a FEM/MoM solution. If MLFMM is enabled on Solver Settings, it will be a FEM/MLFMM solution.
    Volume equivalence also creates a tetrahedral mesh, but this is still a MoM or MLFMM solution (based on whether you activate MLFMM) and not compatible with FEM.
  • Hamsalekha
    edited June 2020
    Dear Mel,
    Noted. Thanks for clear explanation
    Regards,
    Hamsalekha
Welcome!
Welcome!
