Is there a way of assigning thickness to multiple components (individual properties for each component) in one go other than 'Assign Thickness to Midsurface'?
Angad Bedi
Angad Bedi New Altair Community Member
edited December 2023 in Community Q&A
While using the 'Assign Thickness to Midsurface' method, the properties get created with the correct thickness assignment but with the below concerns:
1. Different components with the same thickness are moved into a single property card.
2. The component names change.
The requirement is that for each component, a property card should be created with the correct thickness assignment and with the same name as Solid (Geometry).
Welcome!
Answers
  • Ben Buchanan
    Ben Buchanan
    Altair Employee
    The attached script will create a unique property for each component displayed.  Doesn't do everything you want but hopefully it helps.
  • vijaya_kumar_CAE
    vijaya_kumar_CAE Altair Community Member
    I tried to write an script for the above question. i cant able to run successfully , can anyone who has script knowledge help me out .
  • Jason_Craanen
    Jason_Craanen
    Altair Employee
    I would actually recommend using Parts Browser instead as this capability is completely in core.
    https://www.youtube.com/watch?v=DL5bsj2FCTk&list=PLGNemB0NFb0C3y3JCSSbrJrYXP1IMNJ9e&index=1
Welcome!
Welcome!
