🎉Community Raffle - Win $25
Join and Win
*createlist lines Tcl Modify Command is not working properly
User: "Hypermesh User"
Altair Community Member
Updated by Hypermesh User
While assigning the list of lines(id) to *createlist lines it takes only the first index element of the list.
For example;
Set lineid {101 102 103}
*createlist lines 1 $lineid;
The above Created lines list id 1 should contain three elements 101, 102 & 103
But it always takes only 101 only.
1 - 5 of 51
    User: "llyle_22464"
    New Altair Community Member
    Accepted Answer
    Updated by llyle_22464
    Hi Manoj
    Use eval to expand the list
    eval *createlist lines 1 $lineid
    User: "Viraj_Kulkarni"
    Altair Employee
    Updated by Viraj_Kulkarni
    Hi Manoj,
    As llyle mentioned please use the eval, here I have added a screenshot of commands and the result.
    The 3 line ids are printed.
    OP
    Hi Manoj
    Thanks llyle , Now its working fine,Thanks for your support.
    OP
    Hi Manoj,
    Yes Viraj, I also used eval its working fine.Thanks for checking by spending your valuable time.
    User: "Saurabh pandey"
    Updated by Saurabh pandey
    always use eval command id you are calling any $list items..like eval *createmark line 1 $list
