Optimization will seek the best answer for your problem, and it should be as free as possible.
One thing that you could do in Inspire is to add some manufacturing constraints, such as 'extrusion' control, so that in your example, the material is always used following a certain direction, as it was a extruded profile.
actually not.
Do you think this helps you?
