Hypermesh doesnt find my file i used in a tcl script
User: "Torben0159"
Altair Community Member
Updated by Torben0159
Hello,
first of all im new to Hypermesh and all the scripting. I made a tcl script, which reads a file (like .txt .UFF) and creates nodes from coordinates mentioned in the file. Everything works perfect in the tclsh-environment, it looks like this:
% set fp [open 'test.UFF' r]
file5e9730
% set file_data [read $fp]
1 1 1 1 10 0 0
1 1 1 1 0 10 0
1 1 1 1 0 0 10
I skipped the rest of the code because I think its not necessary. If I execute the script in Hypermesh I get the following error:
couldn't open 'test.UFF': no such file or directory
If I dont read the data file and define the matrix shown above manually, everything is good. So why doesnt Hypermesh find my file? Its definitely in the folder where I start the session from. I hope my problem is clear and someone can help me.
1 - 4 of 41
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Maybe try with full path of file, for example 'C:/Temp/test.UFF' instead of 'test.UFF'
    User: "Torben0159"
    OP
    sry I didnt mention this I have tried this already, same error. What I find weird is that Hypermesh apparently skips the '\'.
    My error message:
    couldn't open 'C:UsersNutzerDocumentsStudiumzz_IAVz_TestSkript_einlesen    est.UFF': no such file or directory
    My line in the script:
    'C:\Users\Nutzer\Documents\Studium\zz_IAV\z_Test\Skript_einlesen\test.UFF'
    Try:
    'C:/Users/Nutzer/Documents/Studium/zz_IAV/z_Test/Skript_einlesen/test.UFF'
    User: "Torben0159"
    OP
    It worked, thank you very much!
