I have this error trying to do a Simulation with CUDA. ERROR : GPU CUDA Solver : The last timestep was not downloaded from GPU to CPU correctly and the simulation data may be corrupted. It is recommended to revert to an earlier saved timestep and save the simulation at that point.
Hi Javier,
It maybe that the GPU ran out of memory? The simulator predicts the amount of memory required but the addition of more particles during the simulation can increase the memory used.
If you rewind one save point and continue does this run OK? You could change the precision in the simulator settings, mixed precision uses less memory than double precision and may help in this instance.
Regards
Stephen
