Solids being imported as Surfaces only?
Dear All,
I have faced a weird issue that I cannot seem to resolve on my own.
It is actually rather simple: I have a .CATPart in CATIA which is a rather complex solid. It is also declared to be a solid in CATIA.
Now, when I import it into HyperMesh, all I get is the surfaces of this solid, but not the solid itself.
I cannot sensibly perform an autocleanup and then create a solid by boundaries, because it is not finding the correct shape as it is supposed to be.
Is there an option that I missed or a setting which causes the solid to be disassembled into surfaces? Or do you think it is more probable that my original solid if faulty?
I unfortunately cannot shape the data as it is classified.
Has anyone perhaps faced a similar issue?
Best Regards,
Lennart
Try saving catia file as STEP format and import it to hm.
As my exp, solids are not neccessary in hm. We mesh on surfs
