clear mark
hello
*createmarkpanel nodes 1 'select nodes'
*duplicatemark nodes 1 0
*createlistpanel surfaces 1 'Select surface'
set targetsurf [hm_getlist surfaces 1]set targetsurfid1 [hm_getentityvalue nodes [lindex $targetsurf 0] 'id' 0];
*markprojectnormallytosurface nodes 1 $surfaceid1
*clearmark all 1
*createlistpanel surfaces 2 'Select surface for mark node'*createmarkpanel nodes 2 'select nodes'
if { [ catch {*surfacemarkaddnodesfixed 2 2 0.00026801845 0 } ] } {
# Handle error
}*nodecleartempmark
*clearmark nodes 1
*clearmark surfaces 1
hm_setpanelproc {hm_callpanel 'automesh';}
In this program at clear mark I am not able to clear the surface stored in surfaces 1
and also not able to retrive surfaces 2 in *surfacemarkaddnodesfixed command
so have look
Thank you
Answers
Hi,
Can you try this?
*markprojectnormallytosurface nodes 1 surfaceid1
*clearmark all 1
# Handle error
}*nodecleartempmark
*clearmark nodes 1
0 -
Just removed $ before surfaceid1
0 -
its not working
same error as mine 'atleast one surface must be selected'
and I want to remove all the mark before going to select surface and nodes for *surfacemarkaddnodesfixed this command
0 -
Hi
You create a list of surfs, so need to use *clearlist instead of *clearmark
below red marks are potential buggy:
'nodes' => should be 'surfs' ?
'*createlistpanel' create a list of surf, but using '*surfacemarkadd...' ==> should be '*createmarkpanel surfs 2 ...
*clearmark all 1
# Handle error
}*nodecleartempmark
*clearmark nodes 1
0 -
thank you very much
*clearlist worked
0 -
in above program suppose I want to run the first part for some definite times
then I will press a perticular key or message (till time it should repeat same set of commands)
and then it redirects to second part is it possible??
0 -
Sorry I don't understand your meaning
0 -
*createmarkpanel surfaces 1 'Select surface for mark node'
*createlistpanel nodes 1 'select nodes'
*surfacemarksplitwithnodes 1 1
so I want to run above program 4-5 times depends on situation
then I should run following once
set targetsurfid1 [hm_getentityvalue surfaces [lindex $targetsurf 0] 'id' 0];
*clearmark all 1
*clearlist surfaces 1
*createmarkpanel surfaces 2 'Select surface for mark node'
# Handle error
}*nodecleartempmark
*clearmark nodes 2
*clearmark surfaces 2
so is it possible??
I tried calling panel 'surface edit' instead of first part but it wont allow rest of program to continue
0 -
yes, it is. i already tell you to use while loop. did you apply it?
0 -
Yes but while loop will continue for infinitely r8??
How can I skip that while loop after some iterations and then go to next command execution
0 -
don't you see break command?
0
