Altair RISE
Nominate Yourself Now!
Include compose functions
User: "Matthieu Pupat"
Altair Employee
Updated by Matthieu Pupat
Hello,
If I define a function in an OML file, how can I call that function from another OML file?
Thanks,
Matthieu
1 - 4 of 41
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hello Matthieu,
               You can call the function using function name along with input arguments.
    I have the following function (test) which does the addition of two input numbers.
    function out = test(a,b)
     out = a+b;
    end
    Way of calling the function:
    test(1,3)
    out = test(1,3)
    Altair Employee
    OP
    Hi,
    This works if both are in the same file. I was referring to the function being in one file and the call in a different one. How can I include the first file in the second one?
    Thanks,
    Matthieu
    User: "manoj kandukuri"
    Altair Employee
    Updated by manoj kandukuri
    Hi Matthieu,
    1st we need to save the function script with the same name and use the function name in a different file.
    say for example
    script 1: save the test function as test.oml
     out = a+b;
    end
    then,
    you can call the 'test' in a different file as a script/function:
    function val = test2()
    a = 5
    b =6
    out = test(a,b)
    val = out;
    end
    hope this helps.
    Thanks,
    Manoj kandukuri
    User: "Dario Mangoni_21783"
    Altair Employee
    Updated by Dario Mangoni_21783
    Please mind that the file should be either:
    • added to 'path' by calling addpath('<pathtotestoml>); however this will affect only the current Compose session (closing and reopening Compose will reset path to its original value)
    • reside in the same folder of the calling function.
    Otherwise the test function that you saved in test.oml won't be found.
