Hey everybody,
running the script attached, the following error is occuring:
I have absolutely no clue why this is happening. Can you maybe help me out?
Kind regards
Simon
Hi,
Why don't you give the full file path?
Hi
Maybe you closed the file before using 'gets'
Try this example not to use 'gets':
set f [open path.txt]
set buffer [read $f]
close $f
foreach line [split $buffer \n] {
set fields [split $line ,]
Thanks Thin, this helped us a lot!
Hi,
