How can I convert components to properties? Now my inherited model consists of several components that are grouped under the same property...
1 - 6 of
61
Please find in attached a simple macro to create one property per component. The name of the property will be the same as the component.
To avoid any mistake, can you delete the already properties assigned to your component ?
At the end, you will need to assign material to the properties created.
Let me know if it works in your case.
Hello,
Could you give more details ? Do you try to import a solver deck model ? Which solver do you use ?
If you import a solver deck, at the import, you can choose how to organize your model (by one component, by property...)
If your question is that you need to export a model organized by property to be able to sort your model outside HyperMesh, you have to create the equivalent property. If you specify your solver deck, we could create a simple macro to create one property per component.
Thanks in advance for your feedback.
