🎉Community Raffle - Win $25
Join and Win
I try to solve a simple task to solve in Altair Inspire, but it is always canceled with "optimization error #1755". What's wrong?
User: "TerezaZ"
Altair Community Member
Updated by TerezaZ
I try to solve a simple task to solve in Altair Inspire, but it is always canceled with "optimization error #1755". What's wrong?image
1 - 4 of 41
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    when you go to the 'run status' window, and RMB in the model name, there's an option of opening the project folder.
    The you should find a .stmod, and a few files. If there's any .out file you can share it here. The .stmod would be also useful.
    User: "TerezaZ"
    OP
    Updated by TerezaZ
    Hello Mr. Koga,
    unfortunately, it seems there is no .out file in the folder. I share the .stmod file...
    Altair Employee
    Hello Mr. Koga,
    your Boundary Conditions (SPC) are all free to move, in all directions.
    So you will have free body movement.
    Please correct it and run again.
    From the .out file in the running folder, it shows you this.
    User: "TerezaZ"
    OP
    Updated by TerezaZ
    Thanks a lot,
    I think that green marked directions are fixed and others are free. Now it is clear where is the problem...
