Modal analysis of a gearbox-housing assembly using the area connector
DWerner
DWerner New Altair Community Member
edited October 2020 in Community Q&A
Dear Members,
my problem is the following:
I want to calculate the frequency modes of a gearbox-housing that consists of two parts screwed with a flange, using OptiStruct as solver.
A validated approach that I want to try is modelling the screws as a bar-element that connects two mpc-rigids, one in the thread-area an the other in the area of the screw-head. The problem that I have is the connection of the two meshes (3D-parabolic with tetra-elements) of the parts in the flange-area. Simply connecting the whole flange leads to unsatisfactory results so that I just want to connect the flange areas in a certain radius auround the axis of the screw.
My first idea was using the area-connector to create rigid-elements, but I still have problems to understand, how it works and if its even possible to do it in that manner.
When I select 'elems' in the location-botton of the area-panel and 'rigid' as type no area-connectors are created independent of every other option chosen.
Using 'node list' leads to really strange connections and its hardly possible to even achieve a creation of some connections.
Does anyone have an indea of a different approach connecting the flange-areas? As far as I know defining a contact is not possible for a modal analysis due to linearity.
Thank you very much in advance!!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2015
    Hi,
    Can you share a picture of the model?
    Contacts may not give a good result as they are non linear and will end up with worst frequency results.
    Maybe you should try with different options in area weld panel.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-19637600-1430191426_thumb.jp
  • DWerner
    edited April 2015
    Hi, thank you for your quick answer!
    I attached some pictures of the model, I hope that helps understanding my problem.
    I also made a Test-Model that originally served to check wether my modelling concept leads to reasonable results, I can be downloaded here:
    https://www.dropbox.com/s/dr9fjisk3m0g8p2/DWerner_Testmodell_AssemblyArea_Beam.hm?dl=0
    As the nets are quite simple, I had no problems creating an area-connector in this model, but when it came to adopting this to the gearbox-housing, I couldn't achieve creating this connector anymore. Are there some ways to remesh the flange area in a manner that creates a really flat and smooth mesh? Maybe this could help?
Welcome!
Welcome!
