Hi,
There are many bolts in assemebly and they are connected by 2 beam elements (there are two elements between one bolt). I want to add one node to that center of it using Tcl if there is no other element is attached to it.
How can i do that?
Regards,
Sanket
In above image there are 3 bolts out of which two are right and in case of third there is little mismatch. and i have added nodes on center of beams which are properly connected.
i want to do it using script.
yes... i want to add node for connected beams not for free 1Ds. How can we do it using Tcl script?
You can use the following algorithm:
Find all the beam elements using config number,
In that list find elements having attached element of same config
find the common node between the two beams.
Hi Sanket,
Please share some images of the use case.
