Run Optistruct solver from Hypermesh
Luca Pietropoli
Luca Pietropoli Altair Community Member
edited October 2020 in Community Q&A
HI,
I have a problem with Optistruct and Hypermesh. I select Optistruct as the desidered solver from Applications>User Profiles but when I run an analysis only it's generated the .fem file but Optistruct doesn't open and thereferore it doesn't work. The only way is to open manually Optistruct, load the .fem file and run the analysis.
I hope I was as clear as possible and thank you for your help
Welcome!
Answers
  • Luca Pietropoli
    edited October 2019
    HI,
    I have a problem with Optistruct and Hypermesh. I select Optistruct as the desidered solver from Preferences>User Profiles but when I run an analysis only it's generated the .fem file but Optistruct doesn't open and thereferore it doesn't work. The only way is to open manually Optistruct, load the .fem file and run the analysis.
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited October 2019
    If you are using HyperWorks student edition then this is the limitation:
    Solvers cannot be started from a command line (only from within the respective panel in the Graphical User Interface)
    https://altairuniversity.com/altair-student-edition-limitations/
  • Luca Pietropoli
    edited October 2019
    Hi Raul,
    I don't have a student edition but the complete license for my period of thesis
  • Rahul Rajan_21763
    edited October 2019
    Do you get the H3d file after analysis?
    Note: OptiStruct is solver so you wont get separate user interface .You can submit run from Hypermesh-Optistruct user profile or Hyperworks sover run manager.
Welcome!
Welcome!
