Combiner Phase Performance
User: "Sem z"
Altair Community Member
Updated by Sem z
Hello
I have designed 4:1 RF combiner PCB in FEKO and for some reason the phase results (I look on S51, S52, S53 and S54 phases values) look very strange.
They also not symmetric, although the design is symmetric.
Attached the design.
What can be a reason for these strange results.
Thanks.
1 - 8 of 81
    User: "Jaehoon"
    Altair Employee
    Updated by Jaehoon
    Please also attach your cfx file, if possible.
    User: "Sem z"
    OP
    Updated by Sem z
    Hello
    Attached the CADFEKO design file.
    User: "Jaehoon"
    Altair Employee
    Updated by Jaehoon
    After reviewing your .cfx file, I found that the inner and outer conductors of the Waveguide port 5 are connected to the same transmission line as below.
    I don't know why you changed the direction of the coaxial feeder, but please make sure the outer conductor should be connected to the ground plane.
    User: "Sem z"
    OP
    Updated by Sem z
    Hello
    I have fixed the connector.
    I still see quite strange results where:
    1. S11, S22, S33 and S44 values are relatively high, although S51, S52, S53 and S54 values are ok
    2. There is a significant phase difference between the channels, although the combination network is symmetric
    What can be a reason for these issues?
    Best Regards
    Semion
    User: "Jaehoon"
    Altair Employee
    Updated by Jaehoon
    Hello
    Best Regards
    Semion
    I simplified your simulation model with infinite planar layer and microstrip ports as attached.
    The simulation results show not-good matching characteristics and  some phase difference among the ports. (The combiner geometry is not perfectly symmetry. Please redraw to modify these.)
    Please make sure the transmission line's impedance are well designed to be matched with 50 Ohm and please locate the center of the geometry to the origin in order to use "Geometrical symmetry".
    If you apply the symmetry for your geometry, then you'll have more balanced results, because of the balanced mesh.
    After that, please add the coaxial cable as a feeder. Then you can concentrate on the feeders.
    Thank you,
    Jaehoon
    User: "Sem z"
    OP
    Updated by Sem z
    Thank you,
    Jaehoon
    Hello
    Thanks for feedback.
    How is it possible to see the port input impedance in FEKO, to check its 50 ohm matching?
    User: "Jaehoon"
    Altair Employee
    Updated by Jaehoon
    Hello
    You can add "Voltage source" to the microstrip/edge/wire port in order to check the input impedance at the port in POSTFEKO.
    However, the waveguide port only provides the reflection coefficient due to its characteristic.
    Thank you.
    User: "Sem z"
    OP
    Updated by Sem z
    Hello
    I have redesigned the combiner to be like Wilkinson bridge.
    Attached its design.
    I would have expected that the phases between the 4 input ports and the output port will look the same but they look very strange, like in the attached picture.
    Also the Sxx of the ports is quite big.
    What can be the reason for both issues?
    Thanks.
