Direct response analysis and Modal Analysis
Hello
I want to a component which will be tested using laser velocimeter and 'Normal surface velocity' will be measured. (at some points on surface of the component)
I want to have this parameter 'Normal surface velocity' as output from directresponse analysis or Modal analysis from optistruct. Is it possible to have it.
Thanks and regard
Pratik
