🎉Community Raffle - Win $25
Join and Win
Hypermesh 2017.2 Node picking problem
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I have been struggling to pick nodes from the screen, specially when the node I want to pick  is the independent (centre) node of an  RBE (spider) with lots of dependant nodes. This did not use to be a problem in older versions. Do other people have this issue and is there any way around this problem? I have tried to adjust  the 'node tol', 'pick tol' on the mesh option but it did not help.
Thanks
1 - 3 of 31
    User: "Pranav Hari"
    Altair Community Member
    Updated by Pranav Hari
    Hi afura
    You can identify the independent node id of a rigid by using card edit option. click on card edit > select the rigid element and set the options as per image > click edit and then you can see the independent node of rigid.
    Then for a further selection of this node you can select using node id
    Altair Employee
    OP
    Thanks but by RBE I meant an RBE2 or RBE3, not rigid body.
    Altair Employee
    OP
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.b8def1cc5f800db9b8dc2bc7a7131f35.png
