You need to add a boundary condition (infinite box)
Split the air in two regions: one for the stator and the second for the rotor
You need to use two mechanical sets (don’t need a compressible)
Hi,
The Fujirawa method works fine on exemple 1, but your mesh is not good enough
In the new version, you will have an automatic mesh
Yann
Hi Abdessamed,
can you check the attached file, i have error with the results in torque and current and can not know the reason, i attach the project and information about it, please help me.
thanks.
Hi,
Checking the file that you send me, here my remarks:
In your case, you sue three phase induction motor? If it is the case, you will find attached a pdf file about the induction motor in Flux. This example is available in Flux supervisor example.
I attached the new Flux project with modification (to do I use Flux 2020; may you will get an error message when you try to open it with the student version). I still get a small value of the torque (but in the new model, I get a positive torque).
Best regards.
Hi
You mean if i have speed in rpm, i should convert it to rad/s by using this formula
(rad/s) =[2*pi*rpm]/60
or the used speed is in rpm
for example if i have speed = 245 rpm and power 75 w the torque equal to what?
T=75/245
or T= 75/(2*pi*245/60)?
yes i saw the example and make like it but i have the proplem in results, so i ask if there is reason to make torque have error value.
thanks.
Hi,
Can you modify the solver used in your project. To do it:
Solving >> solving process options : select edit >> select nonlinear system >> select method for computing the relaxation… modify the method used (use for example optimal method ).
Best regards.
