🎉Community Raffle - Win $25
Join and Win
How to find surface IDs of new surface generated?
User: "Akshay Manthekar"
Altair Community Member
Updated by Akshay Manthekar
Hi Guys,
I have a geometry in which surfaces are penetrating into each other. I have created a macro which splits the surface(s) by another surface. As we know, after splitting, new surface ids would be formed. So, I want to delete the new surface IDs which are formed after split operation.
Can anyone help me which command should I use to know what new surface IDs are formed after splitting?
Your help is much appreciated.
Thanks in advance
1 - 3 of 31
    OP
    Hi Ben,
    Thanks for the response.
    Can you tell the difference between hm_latestentityid and *createmarklast commands.
    I have read the documentation but couldn't understand it.
    It would be very kind of you if you put it into simple words for me.
    Thanks!
    User: "Ben Buchanan"
    Altair Employee
    Updated by Ben Buchanan
    Hi Ben,
    Thanks!
    Hey Akshay,
    Yeah looks like there is some crossover here.  One of the main differences I see is that hm_latestentityid returns the id when the command is run  and *createmarklast puts it on the mark
    So I think this:
    set node1 [hm_latestentityid nodes]
    and this:
    *createmarklast nodes 1
    set node1 [hm_getmark nodes 1]
    would give you the same result.
    Looks like hm_latestentityid gives you more flexibility because you can go back to not just the last created put up to the latest 99 entities created.
    Hope that helps.
