Change 3-D Element orientation
Rahul_P1
Rahul_P1
Altair Employee
edited October 2020 in Community Q&A
Hi,
I have a model of a Sandwichconstruction with 3-D Hex elements as core material.
The material properties of the core are even orthotropic (because there ist used a honeycomb)
Is there an easy way to orientate the solid elements along a vector or axis direction (like composite 2-D)?
Thank you
Answers
  • Rahul_P1
    Rahul_P1
    Altair Employee
    edited May 2015
    Please check if these below scripts will do your requirement.
    You need to download the script and then run this script from the downloaded location by going to file > run tcl tk from within HyperMesh.
    see http://www.altairuniversity.com/support-forum/?mingleforumaction=viewtopic&t=87
    you will find this and other scripts in the altair script exchange, go to learning > script exchange from the altair university website or here http://www.altairhyperworks.com/Script-Exchange.aspx?%3ftop_nav_str=1
    you will need to log in with your university mail id and login credentials you get after registering to the client centre.
    search for the script by just entering orientation in the keyword section.
    once you have found the script click on the download button, once you have downloaded the script place it in a convenient location, then you need to do a file > run tcl tk from within HyperMesh. make sure you have a relevant model loaded in HyperMesh when you run the script.
  • Rahul_P1
    Rahul_P1
    Altair Employee
    edited May 2015
    Thank you it works very well
Welcome!
Welcome!
