🎉Community Raffle - Win $25
Join and Win
Rigid pole impact analysis using RADIOSS
User: "HYOJUNG KIM"
Altair Community Member
Updated by HYOJUNG KIM
Hi. I'm doing a rigid pole impact analysis using RADIOSS solver.
But I have a problem.
When the structure consist of shell element collides with the pole, the deformation does not occur and the analysis is end.
How can I solve this problem?
Please help me...!
I attached the RAD file together.
1 - 1 of 11
    User: "Dr Dhafar ALGALIB"
    Updated by Dr Dhafar ALGALIB
    Hi KIM
    Any thing putted in Rigid will be rigid and can't deformed.
    You search the deformation of your cylinder or the Box?
    I propose
    1- to use a cylindrecal Rigid wall to impact your Box. if you are not interested by the deformation of cylinder
    2- limit your Rigib Body to the upper top and lower bottom then 2/3 of your cylinder can deformed.
    Regards
