🎉Community Raffle - Win $25
Join and Win
Explanation of the weighting factor of a RBE3 element
MarioSUser: "MarioS"
Altair Community Member
Updated by MarioS
Hello everybody,
I am relatively new in Hypermesh. Can somebody explain me what is the meaning of the weighting factor of a RBE3 element, what does it mean 1, what does it mean when the value is 0,5 or 1,5. Changing it´s value what does it mean. And the value, what does it mean, is it distance dependent, etc.? What does it weigh?
Tnx,
BR,
Mario
1 - 2 of 21
    Weighting factor for components of motion on the following entry at grid points Gi,j.
    WTi is used as a weighting factor for the grid points in the group. If a simple distribution based only on the geometry of the RBE3 is desired then a uniform weight is applied to all points. The weighting factors are not required to add up to any specific value.
    OP
    Updated by MarioS
    Thank you Yuvi.
    So if I change the value of weighting factor to 0.5 or 1.5, there will be no change due to the results. It is not affecting the results?
    If I would change the position of the dependent node from the independent nodes, lets say the distance, that is affecting the results, or? And why?
