Is there a configuration setting to have Monarch open all selected reports into one instance of Monarch?
Monarch 2021 would previously open multiple date versions of a text report into one Monarch instance.
Monarch 2022 is opening an instance of Monarch for every text report. (I am actually sending reports to 'Data Mining' from OnBase, but the same happens if I try to open multiple text files outside of OnBase.) Is there a configuration setting to have Monarch open all selected reports into one instance of Monarch?
Thanks!
1 - 1 of
11
Hi Paul,
May be there is an issue with the installation of Monarch on your site.
I could select multiple files (text or PDF) and they all opened in one instance of Monarch version 2021 or v2022.
Regards
Mo
