🎉Community Raffle - Win $25
Join and Win
How to add Topography in wallman?
User: "Surya Teja Dommeti"
Altair Community Member
Updated by Surya Teja Dommeti
Hallo,
How to add topography in wallman?, I want a preprocessed database with topography included. I am unable to add the topography to preprocessed database in proman so i want to add it in wallman and compute preprocessing. I can just see the conversion of topography data but didnt see any import or add option.
Thank you
Best regards
Dommeti
1 - 2 of 21
    User: "Torben Voigt"
    Altair Employee
    Updated by Torben Voigt
    Hi @Surya Teja Dommeti ,
    What format is your topography data?
    Best regards,
    Torben
    User: "mvogel"
    Altair Employee
    Updated by mvogel
    It is relatively straightforward when you start with an urban database (*.odb); I don't see a way to do it with an indoor database (*.idb).
    Launch WallMan
    File > New Project     (NOT File > new database)
    Select a .odb file
    Menu: Preprocessing > Edit Preprocessing Parameters
    In the window that appears, go through the tabs. Note that there is a "Topo" tab where you can include a topography database.
    Once you have defined all the settings, use the menu Preprocessing > Compute Current Project.
