🎉Community Raffle - Win $25
Join and Win
Revolute Joint for Optistrut using Hypermesh
User: "lcjd"
New Altair Community Member
Updated by lcjd
Please guide to procedure of Revolute Joint for Optistrut using Hypermesh.
Objective is to model a lever rotating inside a cylindrical surface.
1 - 2 of 21
    User: "Pranav Hari"
    Updated by Pranav Hari
    Hi lcjd
    Try this option in OptiStruct.
    Go to 1D > Joints
    select the type of joint in your case its a revolute so select the same and select the nodes where you typically want to create the same, whenever you create a joint make sure a create a local co-ordinate system for that particular joint to be accounted for the same.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.c1ce136683e278dd0839df8c14e89daf.png
    This document on joints may also help you.
    https://altairuniversity.com/wp-content/uploads/2017/09/how_do_I_ver1.pdf
    User: "lcjd"
    OP
    Updated by lcjd
    thanks Pranav
