hyperview
after performing topology optimization, I don't know the stress contour and displacement contour for the optimized structure ( Last iteration) are for which iso value specifically?
Because by changing the iso value the structure modifies, however the stress and displacement contour for the last iteration stay unchanged.
1 - 1 of
11
HI,
did you mean that stress values are not changing when compared to the first iteration?
is it possible to share the model and result files?
