Issue with *createbutton.
Hi,
I am doing like below.
*createbutton(5, 'Import Model', 0, 0, 10, BLUE, 'Import Model.', EvalTcl, '$::env(FRAME_DIR_PATH)\IMPORT.tcl')
where FRAME_DIR_PATH = Path of the folder which contains IMPORT.tcl.
it is giving error as
Tcl/Tk script error ...
evaltclscript error:
The specified file 'C:\TEST\IMPORT.tcl' could not be found.
OK
where i set FRAME_DIR_PATH = C:\TEST
any one tell me how to call a tcl file which is not in any HM folders.
Thanks
You can just provide the full path directly in the *createbutton command:
*createbutton(5, 'ImportModel', 0, 0, 10, BLUE, 'macro to import the model', 'EvalTcl','c:\dir1\dir2\dir3\import.tcl')
