🎉Community Raffle - Win $25
Join and Win
Weird behavior of particles.
User: "Fatemeh Hosseini_22198"
Altair Community Member
Updated by Fatemeh Hosseini_22198
Hello every body,
I am simulating Fluent-EDEM coupling.(Particles flow in a turbulent flow with HM-JKR contact model between particles and tube)
I saw weird movement in the particles.
There is a horizontal tube with gravity . In some specific part of the tube particles escape from the wall!
Logically they should settle down a bit, based on the gravity but they don't.
I choose all the parameter from literature.
Could you please guide me what may cause this problem?
(The flow direction is y and gravity is on the -Z direction).
Please see the screen shot of the particles (which is the inlet of the tube).
Regards,
Fatemeh
1 - 1 of 11
    User: "Stephen Cole"
    Altair Employee
    Updated by Stephen Cole
    Hi Fatemeh,
    I would first recommend checking if the simulation is stable with EDEM alone with the set parameters and time-step  The material should settle if there are no external forces and you can plot the kinetic energy over time to confirm this.
    Otherwise I'd check the time-step in Fluent and the time-step Ratio.  With regard to the ratio between EDEM and Fluent this is typically in the range of 10:1 or 100:1 (EDEM time-step lower) however reducing the ratio improves stability.
    On a separate note the time-step in your image does look very low, we do typically run around 20% of Rayleigh time-step however the value of 3e-10 s is low. This maybe OK depending on the case however i'd expect it takes a long time to run.  There are ways of improving simulation speed for example - https://community.altair.com/community?id=community_blog&sys_id=593445c11b2f6810c4dfdbd9dc4bcb06
    Regards
    Stephen
