Import assembly in Simsolid with issues
I am trying to import a large assembly, wich originally has 2828 parts in creo parametric, being one of them an imported/converted part (from stp to prt).
It keeps on loading for ages, asn the best that I could got was 19% , with CAD reader in "legacy" and Resolution "standard".
I've also separated the assembly in two: without the converter part, the remaining assembly was able to load (CAD reader in "legacy" and Resolution "standard"), but the 2827 parts became 6837, with alot of "quilts" , "surfaces" and others... Also some hoovering parts appear.
The imported/coverted part doesnot load at all.
I need some guidance on how to proceed, in a way I can import the full assembly, only with the needed parts
Can you please create a support ticket with the file attached, so we can investigate.
As a workaround, are you able to write a neutral file from Creo and import that into SimSolid?
