Can we select Independent node of many RBE2s at once and create constraints for them in one shot?
User: "Sachin K_22569"
New Altair Community Member
Updated by Sachin K_22569
Hi All,
Is there a way we can select independent nodes of many RBE2's at once and create constraints for all of them just in one shot?
Not preferably not using the window select option, because some of the the dependent nodes will also be in the same plane.
Thank you
SK
